I have an annoying issue with a 1992 740 (Regina, No turbo) -- the shift lock button sticks occasionally, preventing shifting out of park. The FAQs here do have quite a bit of info on this, I know:
http://www.brickboard.com/FAQ/700-900/T ... gOutofPark
I'm not sure if a microswitch and / or relay is involved in shift-locking on this model (I don't think so). So I rather suspect it's the solenoid itself. I crawled around under the car last weekend. The wiring to the solenoid seems OK.
However, my distinct impression is that this problem on the car is much worse in cold weather -- and I haven't seen that mentioned anywhere. Does this help to diagnose the problem, anyone? How should I best troubleshoot?
Thanks,
Rob
1992 740 Shift Lock Button Sticks (esp when cold)
rob2volvos
- Year and Model: 1992 740 / 1994 940
lummert
- Year and Model: 760 1988
- Been thanked: 26 times
I think you may be confusing the overdrive solenoid with the park lock solenoid. The park lock solenoid is attached to the shifter under the console.
1988 Volvo 760 Turbo Wagon
rob2volvos
Yes, I was wondering about that -- Thanks for clarifying at least that much (ie that I'm confused). I googled on 'shift lock solenoid' and came up with this:
http://www.justanswer.com/volvo/4pxfi-1 ... verse.html
So now I glean there is a solenoid and an associated relay -- I'll continue digging on those. I'm looking for links that spell out how to dismantle the console on a 740.
Rob
Rob
- 13 Replies
- 4925 Views
Last post by plumsmooth
- 1402 Views
Last post by Orchid70
- 11 Replies
- 1731 Views
Last post by misha
- 10 Replies
- 1648 Views
Last post by chrism
- 1288 Views
Last post by oizdaman26
