So, driving around with my girlfriend in our beater.... 98 V70 NA with 230K miles. Car got a crazy noise, so I popped the hood. The noise is coming from the serpentine belt. Anyway, nothing we can do since we're like 100 miles from home.
Noise went away and then came back when we stopped at the gas station. Popped the hood and the thing was straight slinging power steering fluid off the serpentine belt lol. Also, the top pulley that's attached to the power steering reservoir is rattling....it's not spinning straight.
Driving home now, with our fingers crossed lol. Any ideas as to what it is? I'm going to take the serpentine belt off and play with that pulley, but I don't know what it is that needs replaced.
Crazy knocking noise from serpentine belt area, power steeri
- phils94850
- Year and Model: 2009 s60 turbo
Id say its the pulley on your powersteering pump is shot..
1996 Platinum Edition
Well, that post was seven hours ago, but I bet he didn't make it even 30 minutes before it just destroyed the pulley and did a dismount on the belt...
but can you just cut the belt on these cars and muscle it along?...I never have tried to drive a Rack and Pinion that way, I have done old recirculating ball.
Another example why the $125.00 a year AAA Premier is a great thing to have when you drive old cars...especially down here in Texas (where everything is at least a 100 mile trip it seems)because it gives you, among other things, two 250 mile tows (actually roll-off trucks) to any shop , your house, wherever. I've bought it for years, seldom used it, but its great sense of security for the price...Oh, and you get one day free rental car while yours is being fixed, as well.
I consider it mandatory for an old Volvo, living out here in the country as I do.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Yeah, AAA is a great idea for one of these old cars.
Your power steering pump blew and needs to be replaced.
'98 S70 T5
2016 Chevy Cruze Premier
HA! Made it longer than 30 minutes boy! I drove it (very nervously) for another hour and a half and made it homebyeboy wrote:Well, that post was seven hours ago, but I bet he didn't make it even 30 minutes before it just destroyed the pulley and did a dismount on the belt...
I was tempted to cut it, but I wasn't 100% sure on what would happen besides a dead battery.... Oh well. In any case, thanks for the heads up guys, about the power steering pump. My buddy has a used one that he's tossing me for $20, so the beater should be back on the road Friday!
- cmblackburn
- Year and Model: 1998 S70 T5M
- Been thanked: 7 times
Yeah, your water pump is timing belt driven so that saved you there. I had a similar experience with my pump, but I was able to baby my car home 20 miles with the pump still going. It destroyed the innards of the pump.
When you replace it make sure the o-ring is still attached to your high pressure line- it's easy to misplace yet crucial.
Before installing the used pump make sure to spin it around and listen for any bad noises or resistance. I got mine out of a 40k car just so I knew I'd be good for it.
Also draining the old ATF from it is a nasty pain- I went to the dollar store and got a cheap spray bottle. With the engine cold I shoved the straw of the spray bottle into the reservoir and squirted as much of the fluid as I could into the bottle, then got the rest out by placing an aluminum pan (very carefully) underneath the low pressure line and disconnecting it. It will keep dripping for a while, so leave the pan there.
When all is said and done, leave the cap off, start the car and do at least ten full left-to-right locks, this will remove all the air from the system.
Good luck!
Good luck!
1994 855 Turbo, 243k "Honey Badger"
1998 S70 T5M, 287k "The Blue Turd"
2004 S40 2.4i, 197k "Cosmo"
2005 XC90 2.5T AWD, 207k "Apollo 13"
2011 VW Jetta SportWagen TDI 6MT, 93k "Zoe"
- 12 Replies
- 11058 Views
Last post by ZionXIX
- 45 Replies
- 8183 Views
Last post by MrAl
- 20 Replies
- 17507 Views
Last post by Hurtfeelings
- 2446 Views
Last post by Ou2mame
- 921 Views
Last post by mar601
