The suspension parts are looking degraded, worn out. The survey shows few AFTs.
Read through several post on MVS. From the cn90 posts and responses, i take it would be best to replace most of these parts at the same time, and get one complete wheel alignment afterward. I am asking again why not go with all Volvo, since the Volvo parts are not that far off Volvo/OEM/SACHS/Bilstein TC mix.
Meanwhile, I have railroad style clunk. Here are two photos of rear subframe bushing while it sat on two jack stand which I had placed under the subframe near each lower control arm. Wheels are off, it was raised just enough to remove the two front wheels for suspension check up.
Driver side rear bushing appears collapsed, it is becoming metal to metal, is it? Also, notice a wider gap between lower part of bushing and subframe.
Is it safe to replace the bushing with few jack stands, and wheels on? Does it need alignment of any kind afterward?
The post from Bill of Durham is bit short on detail for me, and it point to a special tool, where do you find one?
Is there write up with details, like cn90 style.
Many thanks!
Is this a collapsed subframe bushing?
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
xHeart
Is this post applicable today for replacing subframe bushing on '97 850 NA viewtopic.php?t=9720?
Who would lend me the tool?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
That bushing looks good to me.
Ben850
- Been thanked: 7 times
You mentioned a "railroad" type of clunking noise. Have you replaced the lower right engine mount? It would be the one pictured in my avatar photo. That one has a tell tale metal to metal sound when it is collapsed.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
- rspi
Contact rspi..
I've never head a metal sound when that mount is bad. All of mine has rubber under them and are still pretty quiet. You can tell that the one on the left was resting on the sub-frame.
Ben850
Then yours wasn't totally collapsed. Mine was riding metal to metal on the subframe. There was no mistaking it. When I replaced it ( less than an hours work, while taking photos.) The noise, vibration, and hard metal bumping was completely gone.
In the high definition shot, you can click on it for a close look at the area that was making metal to metal contact.
- You can see the collapsed one clearly.
- lower mount front.jpg (17.07 KiB) Viewed 8347 times
- Frame rubbed on the bottom.
- lower mount underside.jpg (17 KiB) Viewed 8347 times
- This one is high definition.
- IMG_1137.JPG (203.25 KiB) Viewed 8347 times
Ben850
Just a few better shots to clarify. Note the differece in the distance between the crank pully, and the subframe, in the before and after shot. It had been rubbing so long, there is no indication of any rubber under the aluminum bracket that moves within the mount.
- IMG_1139.JPG (137.56 KiB) Viewed 8346 times
- IMG_1138.JPG (213.64 KiB) Viewed 8346 times
- IMG_1137.JPG (203.25 KiB) Viewed 8346 times
- IMG_1133.JPG (149.86 KiB) Viewed 8346 times
- rspi
Contact rspi..
There is the difference between blown and destroyed.
xHeart
An attempt to make sense...rspi wrote:There is the difference between blown and destroyed.
The rear subframe with bushing inserted, and bolted, it is a sandwich with plate at the bottom and the frame above. Lifting the frame with jack would lift the subframe with it since the plate at the bottom is bolted on to the frame.
Once the frame is raised on a jack, placing the jack-stand under the subframe, and then lowering the raised frame would leave the subframe fixed at the jack-stand height.
While the subframe is pushed upward against the frame, any gap or separation in sandwich layers, as the photo reveals, suggests erosion of sorts.
Is the bolt loose?
xHeart
Should I replace rear subframe bushing before replacing suspension parts?
Is the gap normal?
Would it deteriorate further?
Would I find problem with bolt or where it treads?
Here are some photos...
Is the gap normal?
- 1995 Views
Last post by Krons
- 817 Views
Last post by theWIFES_S70
- 22 Replies
- 5339 Views
Last post by pkc303
- 1639 Views
Last post by 2forty
- 2354 Views
Last post by June
