So I went to change the battery cables...
j_cd
Year and Model: 1998 S70 GLT
Post by j_cd »
but somebody beat me to it. The tag on this B+ cable says 2006. It must have been replaced under extended service just before my mom gave me the car.
They also replaced the starter-to-battery cable. Below you can see the original one in the wiring loom cut off.
My existing starter cable is stripped at the battery terminal end. I've got the ramac cable from IPD here to replace it.
But back to the B+ cable. It looks good at the fuse box end.
And just a little tore up where it meets the starter cable at the battery terminal.
The engine is pretty well stripped down to the block at the moment, so I can't use my multimeter for testing. Should I just replace the B+ cable with this?
The B+ cable that's on there now says Made in Spain. I don't suppose that matters much if it's fried though.
I found a great write-up here, but he just cleans the cable. I'm still unclear on the replacement procedure. I think you cut the terminal off the old one and pull the cable out the bottom of the fusebox, but how do you get the new terminal in the fuse box? Do you have to pull out the rubber collar? I heard it's almost impossible to get back in.
I'm also putting in a reman Bosch alternator. Hopefully this will solve the dead battery problem. Even a new battery quickly drains in this car. I think I ruined the diode in the alternator a couple years ago when I crisscrossed the battery leads. Yeah, I know, no excuse for that one. I was under stress, the sun was shining in my eyes... nope.
So I stopped working and made this post. Didn't want to destroy that rubber collar without some help. :mrgreen:
TheBraveOne
Year and Model: Volvo C70 2011
Post by TheBraveOne »
j_cd wrote:but somebody beat me to it. The tag on this B+ cable says 2006. It must have been replaced under extended service just before my mom gave me the car.
They also replaced the starter-to-how to replace battery cables. Below you can see the original one in the wiring loom cut off.
I've been looking for more info and topic on battery cables and fortunately I saw this thread. This was my issue a couple of weeks ago and I'm looking for help and advice. So any updates for this? Do you also have an idea of here can I buy some good and affordable cables? thanks!
Pauloil
Year and Model:
Post by Pauloil »
ipdusa.com has the B+ cable. you do not have to take off the rubber grommet to replace the cable, just pull the fuse box down 18 inches or so and work the B+ cable out after cutting the old one, then work the straight part of new cable down through the fuse box and grommet from the top
99 V70XC 158K
95 850glt 188K
mrwillie
Year and Model: 1994 855 base
Post by mrwillie »
Question.... I few months ago I thought that my alt went bad, so I replaced it. Now, my symptons are back( weak, new battery, radio cutting out, etc) but they go away when I give the car gas. And disappear completely after the car has been running for a minute or so until its turned off for more than a few minutes. I'm told that I need to check/replace my b+ cable, but is that the positive cable coming from the battery, cable from battery to fuse box or something else? I havent done voltage drop test yet, but will as soon as I can.
Been thanked: 472 times
Post by cn90 »
mtwillie,
Check GROUND cables.
mrwillie
Post by mrwillie »
Grounds?? Ok... would 10 or 12ga work or could I go w/ a pair of the generic cables from the local parts places?? And you mean the two on the exhaust side of the engine and one on the battery, correct?
Pauloil
Year and Model:
Post by Pauloil »
here's how to voltage drop the grounds. get a good jumper cable. run car at 2000rpm with fan on high, rear defrost on, and headlights. measure batt. voltage. now put jumper cable on motor and neg. batt post and recheck voltage. if it goes up by 0.2V or more, grounds are bad. that said, it is easy to clean the two visible blue grounds, one under the batt and one visible clearly....
99 V70XC 158K
95 850glt 188K
Ringo
Year and Model: 2006 70XC
Has thanked: 32 times
Post by Ringo »
Pauloil wrote:here's how to voltage drop the grounds. get a good jumper cable. run car at 2000rpm with fan on high, rear defrost on, and headlights. measure batt. voltage. now put jumper cable on motor and neg. batt post and recheck voltage. if it goes up by 0.2V or more, grounds are bad. that said, it is easy to clean the two visible blue grounds, one under the batt and one visible clearly....
Hi, I know this is from 2+ years ago, but I wonder if you can explain your explanation :-) WHERE on the engine do I put the battery cable? Do you mean on the frame? And I just putting one clamp (black1) on the motor and one clamp (black2) on the negative post?
2006 XC70 2.5T auto (B5254T2) 125K 2nd owner
1999 V70 XC 2.4T auto (B5254T) 250K Trans failed 2018
1967 122S 2-door auto (B18B) 125K (ex-wife got it 1991)
Has thanked: 1505 times
Been thanked: 3818 times
Right. You are putting a known, good ground between battery negative terminal and the engine block and seeing if the voltage changes.
tryingbe
Year and Model: None
Been thanked: 26 times
Post by tryingbe »
What are you trying to diagnosis?
85 GLH, 367 whp
00 Insight, 72 mpg
