Where to locate jack stand...
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
I appears placing jack stand under subframe would not allow the subframe to fall for replacing it's bushing. So I ask how to take on this task with safety?
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
Interesting, did you find some instructions?
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
The side rails under the front of the doors. Put a tire right up under there as well in case it falls.
'98 S70 T5
2016 Chevy Cruze Premier
xHeart
That would be one side, like changing a tire.jblackburn wrote:The side rails under the front of the doors. Put a tire right up under there as well in case it falls.
The instruction says to raise the car and loosen the four subframe bolts evenly, quarter turn till the subframe is lowered some 1/2". Then undo and replace one bushing at a time.
I would assume the entire front may need to be raised, like an oil change scenario, if not the entire car.
xHeart
The best reference is the one posted by billofdurham. viewtopic.php?f=1&t=50950. Are there more?rspi wrote:Interesting, did you find some instructions?
jblackburn
You have two jack stands right? Put one under each door. Lift by the subframe bar in the middle.
I hope you have an actual floor jack and aren't using that Volvo piece of junk. The car will fall off that thing and kill you.
'98 S70 T5
xHeart
Yes. A 2-1/2 ton floor jack to raise, and two 3 ton jack stands to keep it there. A small 2 ton trolley jack.jblackburn wrote:You have two jack stands right? Put one under each door. Lift by the subframe bar in the middle.
Once raised and jack stand placed safely under the door-rail, do i lower the floor jack and pull it out from underneath the subframe?
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
This is a timely post. I'm in the middle of a tranny swap myself.
Under the door there should be a cutout along the frame that fits a jackstand perfectly. Not sure if this is the "correct" location but it's been holding since about noon today.
- Volvo 850 jack stand location
- volvo 850 jack stand location.jpg (96.5 KiB) Viewed 7004 times
- Cutout for jack stand to fit horizontally
- closeup.jpg (82.6 KiB) Viewed 7004 times
- Sub frame is clear
- subframe.jpg (83.46 KiB) Viewed 7004 times
1995 850 GLT Wagon w/ 200,000 miles
- Been thanked: 504 times
xHeart, not to change subject, but in your other posts, your subframe bushings at 120K look fine to me.
I see no need to replace your subframe bushings.
jblackburn
Yep, just like wheelsup showed! See his tires placed under the frame as well in case it falls?xHeart wrote:Yes. A 2-1/2 ton floor jack to raise, and two 3 ton jack stands to keep it there. A small 2 ton trolley jack.jblackburn wrote:You have two jack stands right? Put one under each door. Lift by the subframe bar in the middle.
'98 S70 T5
