hello dear friends,
I own a '95 850 N/A with auto transmission.I was looking for a newer car with turbo and found a '07 V70 with 119 k kmswhich has a Lpt.the car as 5spd auto trans I decided to buy this car and hopefully on monday I will be buying it. so I believe the Lpt will be a big improvement for me after a N/A volvo 850.. also the car is only 5 yrs old.no problems with engine or transmission.. I will be driving a p2 volvo after the 850 and I want to know if there is something I should know or aware of.
the car gives 180hp of power and the torque 240nm is available between 1800-4800 rpms. I believe the car will accelerate and perform much better when compared to N/A..
any comments?
2007 V70
igel513
- Year and Model: 2003 S60 T5
Check service recs. At that mileage, TB/PCV system should have been changed, if not do it asap. ETM issues should have been addressed by now. Steering and suspension components should be checked. They are a weak point on P2s.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
2007 has no ETM so no worries there. Transmission problems are really rare on 2007's.
Crankcase vent system maintenance is very important so pay attention to that advice.
There is not anything surprising about the P2 except it rides much better and is much quieter.
jimmy57
The ETM was a self contained computer that ran the throttle opening motor and monitored its position.
The system that replaced the ETM on newer models is a throttle with motor and postion sensors but there is no computer inside. The engine computer reads those throttle sensors and the engine computer regulates the throttle motor itself.
The Bosch ETA still has contact potentiometers but they apparently are a much more robust pair of sensors. The ETAs have been going 200K plus with no failures. I have a 185K mile V70R with original throttle and no issues (probably will quit on my next drive for typing that...).
- 1789 Views
Last post by Samzebian
- 2317 Views
Last post by MadeInJapan
- 849 Views
Last post by Iceman12596
- 1167 Views
- 2625 Views
Last post by BWDCBJ
