Will these Volvo "Eurus" 7 x 16 wheels bolt right on?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2861 times
Been thanked: 1332 times
Post by matthew1 »
... on to my '97 850, or do I need spacers?
(can't find any info about them on the Web, grrr)
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
Ooops, they're three spokes, not two. Found the Volvo page with specs.
Aluminum rim "Eurus" 7 x 16
Volvo part #: 30664608
Offset: 49 mm (1.9 in)
Mounted tires: 205/55 R16
Also -> Amazon link
matthew1
Site Admin
Post by matthew1 »
I bought em already, so I'll just try them. Nothing like the actual, physical world to let you know if something works or not :-).
Also -> Amazon link
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Matthew just check that the centre bore is 65.0mm You should be fine. 49mm is the right offset for a wide wheel and will fill the guards nicely.
matthew1
Site Admin
Post by matthew1 »
Will do. Thanks P.
Also -> Amazon link
rmmagow
Year and Model: V70 1998
Post by rmmagow »
Good looking wheel! I want 4 of them and a 6-sp Saffron V70R plopped on top :-)
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
matthew1
Site Admin
Post by matthew1 »
There they are. Need a cleaning, I know.
Also -> Amazon link
chezmike
Year and Model: 2004 xc70
Post by chezmike »
Will these fit a 2004 XC70? They’re specifically called out as not fitting on the wheel site, but I don’t understand why!
Has thanked: 2207 times
Been thanked: 1852 times
I don't know what offset the XC70 uses off the top of my head. Otherwise, if it has a 65.1mm center bore, 45-49mm offset, 7" wide and 16" diameter with a 5 x 108mm lugbolt pitch you should be good. This link may help:
https://www.hubcaphaven.com/c/712/volvo ... _rims.html
chezmike
Post by chezmike »
scot850 wrote: 24 Nov 2023, 19:05 I don't know what offset the XC70 uses off the top of my head. Otherwise, if it has a 65.1mm center bore, 45-49mm offset, 7" wide and 16" diameter with a 5 x 108mm lugbolt pitch you should be good. This link may help:
According to https://www.wheel-size.com/size/volvo/ ... 4-25t--207 the offset is 47-51. Bore and pattern are the same.
