2001 2.4 LPT won't rev smoothly to redline...
ateague
Year and Model: C70, 2001
Post by ateague »
I would appreciate some expert help on my problem...
I have already taken the MAF out and cleaned with MAF spray cleaner. No stored codes. Car just won't accelerate under full throttle. Light throttle and car accelerates briskly up to about to 3,500RPM...but then starts to buck resisting going to red line. Any suggestions on what to check or replace?
Replace MAF?
Is there a recall on the ETM for 2001 models?
Are you supposed to hear the turbo spool up on these cars?
Automatic with about 115k on the odometer.
JDS60R
Been thanked: 3 times
Post by JDS60R »
I check these first.
Check turbo for a rubbing noise or excessive play. (common for these turbo's to need a rebuild at this mileage if non synth oil used)
Check intake vacuum for signs of clogged cat.
Check compression for lower than spec.
Check cam timing on any non CVVT cam gear
Retired
awdsubaru
Year and Model: V70 2.4t, 2001
Post by awdsubaru »
I have the same vehicle. I rarely hear the turbo. You can hear a T5 turbo, but ours is pretty quiet in stock form.
You could also unplug the MAF, and drive the car and see what happens. You will get a CEL with the MAF being unplugged, but the car may run better, and then you will know the MAF is pooched, and it wasnt just dirty.
Current: 2001 v70 2.4T 185,000km
Past: 2002 V70 Base 265,000km
1996 850 glt 290,000km
1996 960 425,000km
ateague
Post by ateague »
Found the pressure hose coming out of the top of the turbo has a split in it, probably due to the high heat in the area. I'll go get one from the stealership tomorrow.
ateague
Post by ateague »
Replaced the hose...but it still resists to rev to red line smoothly.
Replacing the hose improved off idle performance and better mid range acceleration due to higher boost in that range, but it still stumbles in the higher RPM area at wide open throttle.
How would I go about checking the following?
