1996 850 - Fuel filter change tips Topic is solved
How To Change Your Fuel Filter: Guide, Tips, and Tricks
Paul-93-850
- Year and Model: 1993 850 non-turbo
My 93 filter has "quick release" connections. The 17mm open-end wrench was just for pushing the connections away and off from the filter. There was no 17mm nut. I used an almost equivalent SAE wrench because I couldn't find my metric. I jacked car up on the side below the right front door and used a large block of wood in case my jack failed. Used a towel to catch gas drippings. Wear goggles. The rubber caps that come with the new filter to keep it clean are useful to put on the old filter to prevent some of the dripping (I forgot this precaution). A gas mask would have been useful, I'm still coughing from the stink.
- BlackThunder
- Year and Model: 1997 850
- Has thanked: 6 times
- Been thanked: 3 times
In the process of doing this repair. I finally was able to get the lines off of the old filter and put the new one on. now when I try to start the car I have fuel squirting out. I used a screw driver to get the first line off and the box end wrench (as suggested) to get the rear ward line off. Is it possible I damaged the lines?
I'm frustrated. This has taken a lot longer than expected. After the spilled gas dissapates I'll move my car and try again. Any insight? Filter ends not long enough? I purchased the BOSCH OEM filter from FCP Groton.
Dustin
Dustin
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
2013 Volvo C30 T5
Paul-93-850
I'm just wondering if installing it backwards would cause an issue?
- BlackThunder
No, I had it installed correctly - good guess though. I must have turned the bracket holding the filter in place when I was tightening the bolt. Thank you for the suggestion.
I finally got the new filter installed. The lines weren't seated properly. So I basically reinstalled the filter, got some gas on me, and I was able to get my car to work. Boy, that was scary when I would try and start the car and just hear "some liquid" hitting the ground. Hopefully it won't leak in the future. I'll keep an eye on it.
Dustin
Dustin
Dustin
2013 Volvo C30 T5
2013 Volvo C30 T5
i just changed mine and it was the original. Gas lines came off ok after letting it sit for 15 minutes to de-pressurize, and took off the gas cap for a minute as well. But when taking off the retaining band bolt, it sheared after a rotation so had to take it down into the workshop and the inside nut was rusted onto the band so tight it finally took a sledgehammer and masonary chisel to knock it off. Went to the hardware store and got a new stainless steel bolt and locking nut and had to put the retaining band on, bolt not tightened, then finese the new fuel filter into it then tighten the bolt. i finally had to coat the new fuel filter with oil for it to slide in because it was a very snug fit even with the bolt loose.
volvo850black
- Year and Model: volvo 850 1994
Thanks for the great writeup it helped a lot and Sade time while on the side of the road.
MattC 94 854 NA and 96 855 turbo
volvo850black
jar240
- Year and Model: 2006 XC70
This link is dead, now being 8 years old at the time of this writing. Although the post is 8 years oldAJU wrote:refer to: http://volvospeed.com/Repair/fuelfilter.php for pictures
http://web.archive.org/web/200901240009 ... filter.php
(You can find tons of old sites/pages along with past versions at http://archive.org)
