Propane torch flame is laser hot.
After putting back the control arm, all four turned with noise. A moment of panic if the bolt was breaking.
While there, the sway bar end link nuts were takes off also.
Thank you.
Step away from removing the hub assembly, but...
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
xHeart
I am replacing both front hub assembly. I am not sure how many miles more it would have lasted, there was noise at accelerating and decelerating at 30MPH. It has close to 124k. I used 5LB hammer to knock it out after removing the four bolts.
Using rotary tools, it took an hour to remove the layers of rust from the knuckle to make a clean matting surface for the new hub. Below is a photo of OE and the replacement side-by-side.
- 1525 Views
- 12510 Views
- 14 Replies
- 4667 Views
Last post by erikv11
- 2488 Views
Last post by [email protected]
- 1973 Views
