Hi,
My '99 T6 idles at smoothly at 600 rpm. However when idling, the headlights, instrument panel all flicker until I hold it up to around 750 rpm with the pedal which must turn the alternator back on.
My understanding is the 600 rpm level is low and around 800rpm is correct, so what sensor/s would cause this to happen without causing fault codes to be set.
My only code set on a irregular basis is a lonesome P0013.
cheers
Adjusting the idle speed
- 1162 Views
Last post by Graemer
- 657 Views
Last post by Ou2mame
- 458 Views
Last post by tango_1000
- 1331 Views
Last post by 93Regina
- 1355 Views
Last post by erikv11
