no fire to spark plugs
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
btaylor wrote:Does the serpentine belt being off have any significance to this problem?
None at all so long as the battery is fully charged.
btaylor
Year and Model: '97 volvo 850
Post by btaylor »
The oil was changed just 2 months ago...it doesn't
leak or burn oil, so THAT shouldn't have caused
this compression issue. I don't run the car hard,
only around town and like I said all seemed fine
until I went through about 8 inches deep of water
about 6 feet long at about 35/40 mph..then started losing power/compression...
Any more suggestions anyone? It's my only car...
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
Well it looks like you will need to use more oil to restore compression, if this doesn't work you may need to sight the timing marks to be certain your belt hasn't slipped afew notches and destroyed your valves.
regent
Year and Model: 2015 XC60 T5
Has thanked: 2 times
Been thanked: 12 times
Post by regent »
If compression is not an issue, do not forget to doublecheck your firing order :)
2015 BMW 335i
2015 XC60 T5 Premier Plus
2002 S60 2.4 n/a - retired :(
1987 340 DL - retired :(
