Engine light blinking
litalicious
- Year and Model: 2000 S80
The engine light is blinking and the car is putting. Help!?!?!?!?!
Hal Boudreau
- Year and Model: S80 AWD 2004
Sounds like you and I have a simalar problem, but I'm getting a little more info from my message window.... I am going into the dealer monday.... hope i have some info to post
boosted5cyl
- Year and Model: '98 V70 T5, '99 S80
You have a misfire. Commonly caused by a faulty coil or two. Other causes include worn plugs, clogged injectors or issues with the wiring to coils or injectors. Likely an easy DIY fix. Get the codes pulled and see if it reveals which cylinder(s) are misfiring. If you swap the coils between a misfiring cylinder to a good one and the misfire moves with it, bingo.
To find out which cylinder is causing the issue (assuming its running rough at idle too) is to disconnect the electrical connector for the injector for each cylinder and observe the motor. Turns out this is called a power balance test..
In this video he disconnected the coils, but I would reccomend you do it with injectors instead. Easier to get to, safer for the motor and, most importantly, safer for YOU!
Prolonged driving with a misfire can damage\clog your cats and O2 sensors, so keep driving to a minimum until you get it figured out. Or at least, if you find out which cylinder is misfiring, disconnect the electrical connector for the injector on that cylinder until you get the coil replaced.
litalicious
Thank you so much!!!!!!
- 218 Views
Last post by skloon
- 1432 Views
Last post by biohazrd76
- 1565 Views
Last post by Ozark Lee
- 1198 Views
Last post by precopster
- 3628 Views
Last post by Jokerz
