2001 V70XC - preparing for 140K-mi service
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Timing belt component, water pump, and thermostat were added to the list.
Looking at the engine bay I find hints of engine oil under the cam-cover, it is circled in red. So I want to remove the screws holding the cam-cover and diagnose, arrows in green, but the charged-air hose is right over the two green screws.
The charged-air hose is connected with a clamp at either end, and screwed on with torx-20 to hold it in place. Hence, i ask, would removing items with red arrow, and then installing it back cause any issue, clamps in particular?
charged-air hose
charged-air hose
repacs0103
Year and Model: 2004 V70, 2004.5 S40
Post by repacs0103 »
The oil is likely due to a bad seal on the oil cap.
Can't see your pic, but the charge pipe is easy to pull; just loosen the 2 clamps and remove the two torx screws. Then you'll be able to pull the plastic covers.
2004 V70 2.5T- lowered, 16T, 3" turbo-back...my garage queen
2004.5 S40 2.4i- My wife's bone stock DD
2008 Ranger- My company truck DD
