Brittle coil wire harness
stevedud
Year and Model: S80 2000
Post by stevedud »
This weekend I changed the spark plugs on my 2000 S80 2.9 and the looming around the wires connecting to the coils was so brittle, it would just break when touched.
Should I replace the looming or is it ok to have the wires exposed without it?
Also, I think the upper motor mount is bad. When I grabbed the bar going across the engine bay, which the motor mount is connected to, I could twist it easily. My son was also complaining that the car would shake when accelerating.
Is it supposed to twist easily?
Thanks for your advise.
boosted5cyl
Post by boosted5cyl »
Are you talking about the plastic sheath for the ignition wiring? Its certainly preferable to have that, but not essential. You want to be sure the wires arent sitting on sharp corners or anywhere that looks like they might short out.
The engine torque mount bar that goes across engine bay going bad would not explain a shudder, but would explain a thump or thunk as you move off from a stop.
stevedud
Post by stevedud »
I ordered a new upper motor mount and install this weekend. While I'm in there I'll rewrap the wires.
dtropnevad05
Year and Model: S-80, 2001
Post by dtropnevad05 »
You can pick up wire loom here www.delcity.net/store/Loom-&-Loom-Clamps/r_IS1013?mkwid=sj502gMcS&crid=14112218069&mp_kw=wire%20loom&mp_mt=e&gclid=CKvFxqeUhrQCFelDMgodyTsANQ no minimum order and they also sell the OEM clamps. You can also pick it up at most auto parts stores but at about twice the cost.
