Please post an update what you find.oldschoolvolvo wrote:awesome! thank you!
Starter relay?
oldschoolvolvo
- Year and Model: 1979 242DL
it's not a common occurrence, but typically happens when there is a sharp change in the weather, another reason for me to suspect moisture is getting into the relay. i'll pull the relay at some point to look at it, but for some reason was under the impression that my car didn't have a starter relay??
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
I'd suggest starting simple and beginning at the beginning. Ignition switch.
It's a part of the car that gets used every time you drive and does wear out.
From there, run down the circuit towards the starter. It's all in the diagrams.
- 1333 Views
Last post by BEJinFbk
- 771 Views
Last post by ggleavitt
- 1776 Views
- 4390 Views
Last post by WA-Boater
- 1001 Views
Last post by ProjectS90
