850 T5R front end noise (sounds like tire rubbing)...
Just bought this car sight unseen, never drove or looked at it in person. It is a rebuilder and was 900 miles away. Had it shipped here and put it it all together and went for a drive. The passenger side wheel sounds like it's rubbing. Can fade the sound out some when wheels are almost straight but it makes the noise when turned in any direction. Jacked the vehicle up shook the wheels (all tight) Changed tires out, still same rubbing sound. Cv boots are good, shafts don't click or anything. Think the bearing plate on the drivers side may be weak ( light clunk when pulling into driveway) I do know the car sat with 4 flat tires for about 8 months, not sure if this had anything to do with it. I spoke with the original owner and he said that it didn't make any noise the last time he drove it. (and no I don't think he would b.s. me because he told me every tiny thing wrong with it) I am thinking maybe a wheel bearing.. any suggestions?
anmartin44
- Year and Model: 1994 850 n/a
- Has thanked: 2 times
- Been thanked: 2 times
Inner fender cover? check to see if it has all of it little plastic nuts. the wider tires on the R's and even the turbo's can rub when turning. Wheel bearing would really only make noise if you were turning left when there's direct load on the right wheel.
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
- Has thanked: 2864 times
- Been thanked: 1332 times
Yea, agree w/ anmartin44: wheel well liner touching the tire. Or a brake dust guard that gets bent can make a terrible racket.
Checked the inner fenders, also the tires I swapped to troubleshoot were alot smaller. I will check the brake dust guard when I get home from work. It does sound like a deeper noise like a tire rubbing... not a metallic sound. On a side note I did notice the axle shaft tip and nut are both oily.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
May be a wheel bearing (may have something to do with the axle nut being oily). I've heard some make a deep droning noise, and some just kinda a harsh grating noise.
'98 S70 T5
2016 Chevy Cruze Premier
anmartin44
the axle nut shouldn't really be oily...unless PO lubed it up to get the nut off before. Not sure on that one. did you try to re-torquing the alxle nut just to make sure it's not slightly loose?
Thanks for posting the resolution on this, Pantech. For our collective knowledge, how many miles on the car (or the hub you replaced, if you know it's not original)?
- 501 Views
Last post by fszczesniak
- 9 Replies
- 2389 Views
Last post by other_shoe
- 821 Views
Last post by crlande
- 814 Views
Last post by Sommerfeldt
- 1191 Views
Last post by polskamafia mjl
