1997 Volvo 960 a/c problem
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
ITSmyVOLVO
Year and Model: s60 2.4t 2002
Re: 1997 Volvo 960 a/c problem
Post by ITSmyVOLVO »
problem has been fixed!!!
thanks alot for the help everyone. it turns out there was a small leak in one of the hoses coming from the solenoid and also a leaking hose that goes thru the firewall on the passenger side. and as soon as i replaced both, my a/c was working perfect
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Thank you for the update.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
michaelmuller
Year and Model: 960 Wagon
Post by michaelmuller »
I have a similar problem with my 1997 960 wagon. I've tested the vacuum pressure at a couple spots, but can't find the tank under the car. Where is it? I see the photo posted on this page up there, but can't find it under the car. Is there a diagram somewhere that shows its location?
michaelmuller
I found the Vacuum Controller and also noticed a clicking noise when I moved the wires around a little. Pinching a couple of the tubes changes which vent the air flowed from, and at one point it seemed as if some heat came in, but never really full on.
So I pulled it and it looks like there might be some damage. Some solder points look like they've been played with before, and one of the six vacuum ports has black marks, like something was scorched or shorted.
http://mikmuller.com/index.cfm?p=i.572
http://mikmuller.com/index.cfm?p=i.573
http://mikmuller.com/index.cfm?p=i.574
So I just ordered a new one (part number 1388199) from a local parts place for $215, delivered (I know it's $10 more than the online parts place you recommended, but these guys are local and I want to start developing a relationship with them -- this will not be the last tie I will need parts). Should be here on Monday.
