So I replaced the ETM with a xemodex box 6 months ago, replaced the MAF with a new Bosch unit 2- weeks ago.
Best I can tell once the car warms up if I turn it off, let sit for a few minutes and restart the hunting ends and the light goes away and is no longer in limp home mode.
I didn't think a temp sensor could do this, but does anyone have any suggestions or thoughts as to what the problem is?
ETS Light and strong hunting idle 1999 V70 NA 5-speed
ortizmyers
- Year and Model: 1999 V70 NA 5-Speed
- Year and Model: Lots
- Been thanked: 128 times
What light are you referring to? The ETS light or a CEL?
Have you cleaned the throttle bore?
ortizmyers
ets light will come on. I haven't cleaned the throttle bore because it has a rather new ETM...
I will start the car first thing on a cold morning. Without touching the accellerator it will rev to 2k and then drop down and begin hunting. and begin flashing a ets light and after a couple seconds a CEL will fire.
If I toss a code reader on it shows MAF, ETM, and temp sensor.
Exactly which codes are showing?
