How to install a fuel inline check valve, 00 V70
When you say to "mount it directly behind the fuel filter ...Butt it right to the back of the filter" what is behind? which side is the back? Do you install the CV on the side of the line from the gas tank to the filter or on the side of the line from the filter to the engine? I don't want to put the valve where it will cause overpressure. Regards.
Install was relatively easy. Installed the cv on a new fuel filter. Took 1hour to remove the f&@xing rusted retaining bolt. Had to trim the edge of the cv in order for the compression nut to fit. Didn't help the hard start though. Starter died few weeks later. Replaced starter. Car now starts 1st try. Yeaaay.
- shiloh51933
- Year and Model: 04 XC70/'98 V70XC
- Has thanked: 28 times
- Been thanked: 17 times
Only necessary if you don't want to spend money on a new FP.cn90 wrote:I am not sure this mod is necessary as most fuel pumps (Bosch included) have a built-in check valve already.
If U Wanna Play U Gotta Pay!!
Present Volvo Ownership:
2008 Volvo XC90 V8 Black
Previously Owned Volvo:
1996 Volvo 850 GLT Silver
1998 Volvo V70XC Dark Blue
2000 Volvo V70XC/SE Dark Blue
2004 Volvo XC90 T6 Gold
JRL
- Year and Model: Several
- Been thanked: 16 times
and the internal check valve fails in 99s and 2000s (AWDs) which is why these DO workcn90 wrote:I am not sure this mod is necessary as most fuel pumps (Bosch included) have a built-in check valve already.
mrjacobrussell
- Year and Model: 2006 s60R
- Has thanked: 2 times
Does any one ahve a picture of this installed ?
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
2005 v50 t5 AWD for sale
I have a Chinese DICE, works well.
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
JRL
Unfortunately no, but picture the fuel filter (look under your car) than picture a (approx.) 4" brass rod butted to the back of it.
mrjacobrussell
I just got my check valve. I have a 2000 xc se v70 California car . Should I just cut the fuel line or are you saying compress /attach the check valve to the filter nipple ? and use the extra barb to press on the fuel line clip?
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
mrjacobrussell
guys I would really appriciate a picture as I amd totaly fricking confused on how to install this. the way I see it it has to be installed inline with the fuel line so I have to cut the existing line before or after the fuel line.
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
JRL
Yes, you do
Buy yourself a new fuel filter, (you probably need it anyway), than attach the CV to the new filter first
Then remove your old filter, attach the front portion new filter with the attached CV behind it.
Measure, than cut the line and attach it to the rear of the new assembly
- 682 Views
Last post by v70XCSteve
- 350 Views
Last post by coop
- 1456 Views
Last post by RickHaleParker
- 14 Replies
- 2560 Views
- 1110 Views
Last post by dougrock
