did put some BMW e36 Ci internals in my DOT headlights. I adjust them by using two pieces of m6 thread that are stickin out
of the back. It was a easy and pleasant fix giving me a lot of light already, before putting in HID.
home made headlights
redcross850
- Year and Model: 850SW 1995
- Year and Model: Lots
- Been thanked: 128 times
Is the electrical plug the same? Did you need to cut any plastic to achieve this? Must say the result looks similar to a HID and very unusual though looks great at the same time.
redcross850
There was a little bit of cutting at the back, because the lenses and reflector go in a little deeper. Only did put in the inner part
of the BMW . It's just a frame that you put in and connect to the Volvo wires in the Volvo headlamp. So you keep the original connector.
xjflexer
- Year and Model: '96 850 R Wagon
Those look REALLY good. I'm sure they are a vast improvement over stock. One thing you might want to think about is getting non-diffused headlight lenses (i.e. clear glass). the BMW headlights are designed to distribute the light beam unassisted by a headlight lens for optimum efficiency. Adding the diffused factory Volvo lense over the BMW assemblies will diffuse light that is essentially allready diffused. In other words, your lighting will be better with clear lenses. I know Lucky sells them on the ARD website (I no affiliation with him other than being a customer.)
redcross850
Hi,
diffusing is minimal. When i adjusted them on a Bosch headlight tester, the image i should have was perfect (european headlights)
I used american DOT headlights from Volvo which have much clearer glas then european ones. they were a gift from someone
who imported a US spec volvo.
Did you take pics or do a write-up or something when you did the light? They look great!!redcross850 wrote:There was a little bit of cutting at the back, because the lenses and reflector go in a little deeper. Only did put in the inner part
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I noticed that iPd sells high output bulbs, has anyone tried them?
redcross850
redcross850
- 16 Replies
- 4926 Views
Last post by vtl
- 3492 Views
Last post by ShadowDancer
- 27 Replies
- 5205 Views
- 1947 Views
Last post by 850 LPT
- 2413 Views
Last post by shiloh51933
