Good engine cleaner....mess to clean up
nzvlnr
Year and Model: 1999 s70t5
Post by nzvlnr »
My s70 blew the hose that connects to the engine block from the oil trap ( parts on order) and I now have to clean a bloody mess......
Can someone reccomend a good degreaser that will not damage the rubber seals, wires or anything else on the front of the block? Thx!!
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Just about any will do. I like Gunk but just about all of them work fine.
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
I pretty much head to AutoZone and grab the cheapest can of engine cleaner. I may have bought two cans when I first got around to cleaning just to be sure, but one should do fine if you have a cleaning schedule.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
Been thanked: 504 times
Post by cn90 »
Fix the broken hose first, then Castrol Purple Cleaner, then gentle amount of warm water.
Again, you don't want water to enter the engine, so fix all broken parts first.
nzvlnr
Post by nzvlnr »
OF COURSE....PARTS ARE ON ORDER AND i WILL TRY A DIFFERENT CONNECTOR.....ANY IDEAS?
SUPERBRIK
Year and Model: 65&68 122 sedan&wago
Post by SUPERBRIK »
Purple Power cleaner... It even will clean the charcoal colored plastic trim on the car.
kiss4afrog
Year and Model: 850 1995
Post by kiss4afrog »
Best bet is purchasing a can of engine degreaser at an auto parts store and going to a self serve car wash. Just before going in spray down the engine compartment and leave it running while you hose down the engine. Keep the wand a few feet away at all times and have the engine running. Works great.
You can never have too big a Turbo !
mrwillie
Year and Model: 1994 855 base
Post by mrwillie »
I use simple green for all of my degreasing jobs now. Its bio-degradeable( or supposed to be) and smells good, too.
dbm123
Year and Model: 1999 V70 GLT
Post by dbm123 »
kiss4afrog wrote:Best bet is purchasing a can of engine degreaser at an auto parts store and going to a self serve car wash. Just before going in spray down the engine compartment and leave it running while you hose down the engine. Keep the wand a few feet away at all times and have the engine running. Works great.
I second this... It's what I do...
Current Volvos:
2004 C70 HPT (wife)
2002 S40 1.9T (daughter)
2001 V70 XC (daughter)
1999 V70 GLT (now dead)
1998 V70 GLT (son)
The other car: 2003 Saab 9-3 SE Convertible (mine)
rspi
Post by rspi »
If you do the car was hose thing, try to make sure you do it with the car/motor cool or cold. If the engine is at temp, the cleaner may dry before you rinse it off and cause staining.
Do not spray the distributor or much over the spark plug cover. I'm surprised how easy it is for water to get into the spark plug holes.
