S60 sunroof problem
ccordsario
Year and Model: s60 t5 2002
Post by ccordsario »
Hi guys im a rookie with volvo and on the page.
I recently purchased a 2002 Volvo S60 T5 and the sunroof doesn't open. I have tried all the open/close process to reset the ecm and anything work. All the lights works fine, except the left screen on the dash. The alarm works fine with the remote and the siren works if a press the panic bottom. Any suggestion of what else i can do??? Thanks for all your help!!
zangado
Year and Model: 2002 S60 AWD
Post by zangado »
Check to see if the fuse is blown,that could be the reason. Sounds like it's an electrical problem.
ccordsario
I already check the inside fuses and nothing. Idk if the sunroof have other fuse but at least the one that is in the driver panel is good...the sunroof have another fuse???
