2000 V70 R
Have title in hand. Will post more pics.
Vin YV1LV60D6Y2675740
Passed emission inspection 10/12
Silver ext, Black int, 3rd Row seat, Originally option with surround sound stereo was remove by previous owner.
$3200 located in Castle Rock, Co, 80104
Oil change every 5k w/ Mobil 1 High Mileage
199,000 miles EXT is 8/10 INT is 8/10
Needs transmission work. Shift solenoid 4 problem PNY replaced. Last service 142k
Recent work:
Timing Belt, Water Pump, Idler bearing, Tensioner, serpentine belt, expansion tank, lower expansion tank hose, expansion tank cap, temperature sensor, Heater Core, thermostat (180degree),radiator. Spark plugs .197,000
Leak from water pump so had the above parts replaced, car did not overheat.
Lower control arms, tie rod end links, sway bar end links. Nivomats do work correctly.
Akebono Euro Pads front , ATE Premium One Disc front.
Fuel Pump, used from Erie Volvo
Intercooler hoses
03/09 142k new catalytic converter
04/09 145k Biststien Heavy Duty Front Struts
2000 V70R Denver, CO $3200 obo
roadrageinco
- Year and Model: 2000 v70r
roadrageinco
