Back to my favorite place for everything Volvo!
Friends, I've been following this awesome tutorial for replacing the headgasket on my XC, but I am stuck due to the CVVT cam. (I haven't removed the belt yet since I don't want things to go awry) I've read Lee's post regarding VVT timing, and I am ready to move forward.
I can't seem to find anything that shows how to make the Cam locking tool.
I went to vegasjetskiers post here, but the links have long expired.
Any help would be well received!
Also, why is getting the turbo out such a monster pain???
Instructions for DIY Cam locking tool
- Has thanked: 311 times
- Been thanked: 817 times
I know the Haynes manual describes how to make a tool to lock the cams from the rear. What about the traceystruesoaps tutorial, the granddaddy of them all, anything in there?
LASteve
- Year and Model: 2015 V60 T5 E-Drive
I don't have access to a printed Haynes (the website doesn't even cover Volvos anymore??)
Tracy's has a great description, but I don't think it will allow for the high torque limits that need to be applied once the cams go back on.
Current Sled: 2015 V60 T5 E-Drive
Volvos I used to own:
02 V70XC
99 V70XC
97 855 NA
87 245 DL
02 V70XC
99 V70XC
97 855 NA
87 245 DL
Not sure what you mean about high torque limit? Is that a VVT thing? The basic tool is only used to reassemble the cams with the top cover. Doesn't need to be super beefy material, I've used one made from perforated metal strips. If you need to hold the cams in place after that, you could slip a thicker bar through the slots, I suppose.
I sent you a PM.
I sent you a PM.
JDS60R
- Been thanked: 3 times
If you are taking off the VVT you will need strong stock as the torque is 90ft lbs. If you are just aligning the cams you can use light stock or just make sure the slot in the cams is level with the head gasket surface.
I usually remove the vvt to replace the seals and use a home made tool made of 90 degree 3/8 stock with tabs bolted through it. The intake cam is a little higher than the exhaust if I remember correctly.
Retired
LASteve
From what I've read, When timing the VVT, one needs to tighten the hub to 89 ft/lbs. I feel like some
Steel shims on a wood lock might bend. Not something I'm willing to risk.
02 V70XC
99 V70XC
97 855 NA
87 245 DL
02 V70XC
99 V70XC
97 855 NA
87 245 DL
Check out the youtube videos by robinsonsauto.
http://www.youtube.com/user/robinsonsauto/videos?view=0
His latest one on fabricated tools includes the cam locking tool he made when he replaced the head
gasket on a 99 S70GLT. He made a series of 4 videos for the head gasket job.
He might even be willing to make the tool for you, can't hurt to ask.
LASteve
Cheers again to all of you, and this website in general.
I ended up making a heavy duty version of the Tracy's method using 1/4" ply and some thick steel inserts.
Cams didn't move a cm.
02 V70XC
99 V70XC
97 855 NA
87 245 DL
02 V70XC
99 V70XC
97 855 NA
87 245 DL
- 52 Replies
- 13007 Views
Last post by MamaForestCritter
- 1128 Views
Last post by cuhfs
- 796 Views
- 491 Views
- 9 Replies
- 872 Views
Last post by ionianp2
