01 V70 FWD, 130k. MN Winter, been a little chilly here as of late (-15.) Recently received the P0116 coolant sensor CEL. Temp gauge hasn't been up to the halfway point since it got really cold out. Ok, new thermostat and OEM temp sensor and a drain. Previous owner did pump 18 months ago with new fluid.
Took out the old therm and sensor and saw black deposits that I have never seen before. Inside of the thermostat body looks good. Fluid that came out wasn't dirty. Are the deposits anything to be concerned about?
2nd question, the fluid that came out looked a bit like diluted apple juice so guessing it's probably Zerex G05? Have always used the Volvo OEM coolant (what's $10-$15 over 30k miles) regardless of vehicle (740,940,960,S70) and plan and refilling with Volvo.
Thanks!
01 V70 thermostat deposits?
Update...
New thermostat and temp sensor are in, coolant drained and filled with Volvo blue. Everything works well, temp goes to halfway rather quickly and stays there. Only had to top off once with about half an overflow tank. Nice to have heat again! Just in time for some more really cold air.
Boiled the old thermostat and it opened about 8-12 degrees sooner than it should of. Boiling did not remove any of the black deposits, still no idea why the deposits are there on the old therm & sensor.
05 S60 AWD 137k; 01 V70 FWD 198k. Also 2010 Ford Fusion SE FWD 6-speed manual
Previous rides:
04 S80 T6 198k; 98 S70 236k; 95 960 #1 229k; 95 960 #2 257k; 91 740 241k; 88 940 155k, rolled, totaled, no injuries
Previous rides:
- 22 Replies
- 5314 Views
- 837 Views
Last post by oragex
- 757 Views
Last post by precopster
- 17 Replies
- 2006 Views
Last post by MarcM
- 10 Replies
- 1721 Views
