My 1st P2 (XC70) Project impossible? Topic is solved
DGM
Year and Model: V70 2.4i 2005
Been thanked: 3 times
Post by DGM »
precopster wrote:Thanks Mike I had this on my 2000 5 speed auto V70 and had it removed at the dealer
Totally different fault to this gearbox. This car edges forward in neutral and has no reverse. I suspect valve body failure; fluid is black and worth a try to replace.
Could it be that the PNP switch is incorrectly set or the shift linkage out of alignment? Just my thoughts...
Keep up posting it is interesting to follow.
V70 2005 2.4i 195,000km, sold
S70 1998 T5 355,000km, sold
960 1994 80,000km, sold
760 1990 Turbo 265,000km, sold
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
As engine is loaded when in P or N it has something to do with hydraulic flow rather than what gear the TCM thinks the engine is in. Something is slowing down the engine. The reverse lights work (well they did yesterday but that's another story)
Right now I have to rebuild the original ETM to see if that's why I'm getting ETM codes and Reduced Performance messages.
A new problem which has surfaced this morning is no rear doorlocks/tailgate locks/fuel flap power as well as no rear wiper and no reverse lights. All fuses are fine so it's time to see which relays in the rear compartment are shared.
mikealder wrote:If the fluid is that bad a flush and the addition of a MagnaFine filter to the return line might not be a bad idea, after that if it is still playing up consider removing the solenoid valves and opening them up to clean them before resealing and refitting, it is surprising how much crud builds up in these when the fluid is bad - Mike
Mike I think if I go to that much trouble I'll just replace the valve body either with a new '03 one or a remanufactured unit as these symptoms don't seem to be solenoid problems; remember it actually drives and shifts really well in D. Also 1st gear and reverse share the solenoid, however only 1st gear works.
Driver's side spring seat or what's left of it. With spring compressors, an air wrench and a grinder got the suspension unit out and put in a new spring seat. The grinder was used to cut the last 1/2 inch off the top of the spring seat so I could have access to the star nut. It was an original spring seat with an 00 build year so not bad for 12 years.
Car also has a broken or dislodged Park lock.
DGM
Post by DGM »
precopster wrote:Car also has a broken or dislodged Park lock.
The shifter cable mechanism/PNP switch combination could be out of position or alignment.
It is something to consider. The following thread is not applying directly to your model/year but it can help.
PNP Removal & Installation w/ Photos
Thanks DGM for your input. The PNP has a certain range of adjustment which can't limit the gear positions.
Park is there, as are the other positions. They all show up on the dash as correct when cycling when the shift cable is connected.
When the car is placed into Park with the wheels down it jerks forward and almost drives. This has damaged the gearbox at some stage prior to my acquisition
I've also disconnected the cable and cycled the gears by hand on the lever. Park definitely won't lock the 'box.
Battery was flat so put in another charged battery and looks like the BCM sprang back to life by giving power back to rear wipers, rear door/tailgate locks and allowing reverse lights to work...... Looks like this is going to be a long and dusty haul.
mikealder
Year and Model: V70 2000
Been thanked: 13 times
Post by mikealder »
If you have seen the following pdf then appologies, if not it might give you some ideas with the autobox - Mike
http://www.sonnax.com/system/pdfs/87/or ... 08-RCW.pdf
Thanks Mike, haven't seen that one yet; it's certainly a very detailed fault finding manual. When it's time will get to know it better.
I drove the XC this morning and the forward progress isn't too bad; the trans shifts and downshifts into all gears, though downshifting with the geartronic gives some terrible backlash. The really bad thing is that the motor breaks down at anything over 40% throttle. I've rebuilt the ETM with a contactless sensor and recalibrated it to the same output voltage as the old sensor but I still have an ETM code relating to low current. I'm going to check the earth at the engine block and see if this sorts things.
