Need a rebuild TRW rack for 97-850
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Would jy my option?
Been thanked: 504 times
Post by cn90 »
Has thanked: 311 times
Been thanked: 817 times
Erie Vo-Vo is a good source for rebuilt racks.
I had mine rebuilt at Jorgen automotive.
http://volvospeed.com/vs_forum/topic/14 ... ring-rack/
xHeart
Post by xHeart »
A local reman shop says my rack's shaft is rusted, therefore can not be rebuilt. Says the boot let the water in.
xHeart
Post by xHeart »
A jy find. 1995 850 GLT - 100000 miles. Will it fit once rebuilt?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
I believe ANY rack from an 850 should work. I think my research showed that the SMI racks started with the 98 model year.
Double-check the boots on the tie rods to be sure they say "TRW".
'98 S70 T5
2016 Chevy Cruze Premier
xHeart
Post by xHeart »
Helpful hint. I will.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Careful
Racks are all different and many years use multiple racks that are not interchangeable
You need the numbers off your rack (on the bottom) to make sure you get the right one
xHeart
Post by xHeart »
JRL wrote:Careful
I found this marking MCW 5 on the rack of my 97-850. The location is surface below the bolt to the mount.
Should it be matched with the replacement JRL?
Marking on steering rack - MCW 5
JRL
Post by JRL »
IIRC the number is longer but try it
