Having lots of fun today going over the ECC system in my new-to-me 97 850T5. Evil contraption!
Right now: Vent controls (the round knob) do nothing. It's stuck on half-front vents, half defroster. Evil blinky lights. Haven't read codes, hoping to not care about them.
Goal: Get it on front vents only. Everything else is optional, and probably more trouble than it's worth. Just give me cold AC in the face... It doesn't get cold in Texas
Did a bunch of reading and found the split damper shaft (behind the glovebox) issue. Disassemble glove box and remove motor, yup, shaft is split.
But it seems that shaft only controls the mix between the upper vents and the floor vents? I can turn it by hand, when I do, it goes between all air to the floor at one extreme and the half-front-vents, half-defrost setting (with floor vents closed) at the other extreme. It doesn't turn very far, less than a 1/4 turn.
So, is there another motor/damper combo that controls the mix between the front vents and the defrost vents? Or maybe closes/opens the pathway to defrost? If so, where do I find that beast?
OR, should that split shaft turn further, such that if it kept going, it'd direct all air to the front vents?
Thanks!!
