740 GLE 16 Valve - Flywheel issue
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
bedem
Year and Model: 740GLE 1990
Post by bedem »
Last Monday I had a local mechanic replaced the rear crankshaft seal and to do this he had to take the auto transmission out. When it was all re-assembled the car ran very badly, would not idle, hunted up and down in revs and when driven was down on power.
They had the car all last week and could not find the problem. I took it to another mechanic today and he had his diagnostic guy look at it and concluded that the flywheel is installed wrong. Is this possible? I thought that there was a locating lug that meant you could only put it in the right way. Can it be installed offset?
When the transmission went back in he had to replace the flywheel sensor as it was damaged when removed. I suspect that the replacement sensor could be the wrong one and it may be the source of the problem. What do you guys think?
BedeM
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The flywheel can be installed out of line as shown in the attached.
However, the impulse sensor which sits on the top of the bell housing may indeed be the wrong one. There is a sensor, part number 271949, that is only to be used on any of the 16 valve engines fitted to the 740. The 8 valve engines sensor part number is 1317030.
740 flywheel.pdf
(182.28 KiB) Downloaded 274 times
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
bedem
Post by bedem »
Thanks Bill.
The Volvo people here in Oz tell me that the same sensor fits all three models (turbo, 16 valve & 8valve) here in Australia. Very frustrating for me as my car currently runs like a dog and the expert reckons that it's the flywheel that's positioned wrong.
My mechanic wants to pull the gearbox out again on Monday to be sure.
BedeM
JerryC
Year and Model: 93 940
Post by JerryC »
There is an easier way to check. With no.1 at tdc, the 'space' on the flywheel should be visible at the starter hole. Of course, you have to remove the starter. 'Space' is where there isn''t one of the holes that the sensor reads.
bedem
Post by bedem »
Well the gearbox was removed yesterday afternoon and after much guessing at where the right position was, it's back in the right spot. The diagram didn't help the mechanic as there didn't seem to be the markings as shown.
Inga (my 1990 740GLE) is back running right and set for a road trip to southern NSW from her home on the Gold Coast.
BedeM
billofdurham
Thank you for the update.
Bill.
Previously:
Husseinelhajj
Year and Model: 740 gle 1990
Post by Husseinelhajj »
billofdurham wrote: 19 Feb 2013, 12:24 Welcome to Matthew's Volvo Site.
740 flywheel.pdf
Bill.
This pdf file helped me to fix a 740 gle! I can't thank you enough man!
