95 850 T5 rattle noise coming from front of the motor.
anmartin44
- Year and Model: 1994 850 n/a
- Has thanked: 2 times
- Been thanked: 2 times
I'm pretty sure an NA won't throw the cat code due to it not having an o2 sensor after the the cat. mine was completely blown out and i never got any codes.
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
Dont let the neighbors catch you doing this, but if you put a short piece of hose to your ear, you can isolate where sounds are coming from to the nearest 2.54 centimeters, give or take 3/8 of an inch. This can really help you diagnose which part you need to replace.
jacobharding
- Year and Model: 87 740 T.I.
My dad showed me that trick one day. I thought he was nuts at first but it really does work. On the plus side If you plug it into the vacuum T it also will get a lot of the old wax out of your ear. Two birds, one stone.
I am not an expert mechanic, but I will attempt any repair. Worst case scenario is I screw it up worse than it was.
87 745 Turbo Intercooler...333k, all original!
96 850 Turbo wagon "totalled - parting out"
94 850 Turbo wagon waiting for tranny
2 94 855's gone
They're all gone now....
2 94 855's gone
LOLOLOL....dont forget to wax the car afterwards - its both green and frugal...well, more orange actually
rmmagow
- Year and Model: V70 1998
I have an AWD turbo and a second 02 sensor but never had a cat code. I don't hear very well, but maybe I can get my wife to try the hose trick to isolate the noise. I had the car on ramps, idling and rattling away. I banged on the cat but the sound didn't seem to change much. I'm sort of hoping it is the tensioner as the is easy to change, cat, not so much.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
woodchopper
- Year and Model: 2010 S80 T6 AWD
woodchopper wrote:I have this problem on a 98 V70 FWD. With a stethoscope in seemed to be the spring part of the serp belt tensioner. Took tensioner off and idler bearing seemed okay, so packed it with grease and put it back on car. Still noise. Does something happen in the spring part of the tensioner that lets it rattle at low rpm.
I sure wish I had taken the rattle more seriously, it turned out to be the idler on the timing belt and it cost me an engine. Lee's suggestion of taking the serpentine belt off would have solved it for me. Very expensive lapse in judgement.
