I tried searching for the answer to this question, but I could not find the answer. I plan on replacing all of my vacuum hoses in the spring with special attention being placed on the secondary air system hoses. I'm currently pricing out the differences between using silicone hoses and regular rubber hoses. If I use rubber hoses I know I will have to replace all the vacuum elbows (both straight and angled elbows) on the various valves and on the charcoal canister. The price of these connections is more than I expected even when factoring in the standard elbow kit offered by IPD. I feel like I remember reading a previous thread where someone said they recently replaced all their vacuum hoses with silicone and did not need to use any rubber elbows. If this is true, then the cost of using the silicone hoses will be about the same as using rubber hoses with all the connections. So my question is, do I need to use the vacuum elbows with silicone vacuum hoses? Thanks in advance.
Also, I have a 1998 s70 non-turbo. I've read that I'll need the following hose sizes: 4mm, 6mm, 8mm, and 10mm. Can anyone confirm this?
Vacuum Elbows Required with Silicone Hoses?
SwampRat5605
- Year and Model: 1998 S70 N/A
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Nah. It can make most of the bends without kinking.
Sizes sound right. You'll need the most of 6 mm.
http://volvospeed.com/vs_forum/index.ph ... se-how-to/
'98 S70 T5
2016 Chevy Cruze Premier
mercuric
- Year and Model: 1997 850 T5
- Been thanked: 2 times
Shop around online... And don't forget ebay.. Last time I did this I got an assortment of silicone goodness for almost nothing there.
I also prefer to use brass or stainless fittings if I need couplers, bends, etc. They don't get brittle and crack so quickly (texas heat is brutal!) and along with the purdy silicone hose, add a nice visual touch.
SwampRat5605
Thanks for everyone's help so far. I have one more question. It's probably a long shot, but I want to know the hose size of the red hose in the attached picture. Based on the link posted by jblackburn it's either 4mm or 6mm. Anyone know?
- Charcoal_Canister.jpg (47.25 KiB) Viewed 888 times
jblackburn
Is that a hose to the EVAP canister? If so, I believe that one's 8.
'98 S70 T5
- Been thanked: 504 times
Although I am a purist when it comes to ignition parts (I only use Bosch spark plugs, Bougicord wires, Bosch cap/rotor), I must admit that when it comes to vacuum hoses and their elbows, I use generic hose with appropriate sizes.
All of the elbows in my car come from generic hoses.
rmmagow
- Year and Model: V70 1998
SwampRat, that diagram you posted. Is the square charcoal canister located under the driver's side front near the fender in your car?
Thanks,
Thanks,
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
SwampRat5605
I currently don't know where my charcoal canister is located. I tried looking under the hood the other day, but I couldn't find the canister on the driver's side since the battery is in the way. Though based on the vacuum diagram on the hood of my car, I'm 95% sure the canister i located under the driver's side front near the fender. I'm doing any oil change tomorrow, so I'll be able to get a better look when doing so.
SwampRat5605
I can confirm that my charcoal canister is located under the driver's side front near the fender. Also, it is rectangular in shape and not circular.
- 16 Replies
- 3115 Views
Last post by MrAl
- 34 Replies
- 11038 Views
Last post by theWIFES_S70
- 13 Replies
- 3025 Views
- 1184 Views
- 3042 Views
Last post by wizechatmgr
