Amazingly well documented Odometer Fix
This topic is in the MVS Volvo Repair Database » How to Fix the Odometer on your Volvo 850
Old Bakelite
Year and Model: 1997 850 T5
Re: Amazingly well documented Odometer Fix
Post by Old Bakelite »
Has the link to this odometer fix been removed?
Thanks.
1997 850 T5 Wagon 64k (Hers!)
RIP - 1997 850 GLT Wagon 167k...up in smoke.
Klausc
Year and Model: 1995 855 Turbo
Has thanked: 5 times
Been thanked: 15 times
Post by Klausc »
Klaus
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1247 times
Post by matthew1 »
Thanks Klaus. Ooof, that's embarassing.
I fixed the head post's link.
Also -> Amazon link
Old Bakelite
Thanks Klaus and Matthew!
Old Bakelite
OK, last thing before I get started is knowing the actual mileage so I can put it right on the odo...but now I do not know how to do that. Is it possible from the OBD? Do I have to go to Volvo dealer only? Or maybe it is not possible at all on 97 year model?
Thanks for advice.
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Old Bakelite wrote:OK, last thing before I get started is knowing the actual mileage so I can put it right on the odo...but now I do not know how to do that. Is it possible from the OBD? Do I have to go to Volvo dealer only? Or maybe it is not possible at all on 97 year model?
Thanks for advice.
It is pretty much a dealer only thing after '95. An independent shop that has a Volvo scan tool can also do it. The problem is that most of them, dealer service departments included, don't know how to find it in the menu. It must be buried pretty deep in the menu tree.
Old Bakelite
:roll: ...how frustrating. I have just got back from the Volvo dealer and he connected his Volvo scanner. Nothing came up in the main menu and he said it was not possible. I mentioned that on the forum people say it is possible to interpret certain codes and he said these older cars were not networked blah blah blah (I gave up listening at this point).
Thank goodness for forums like these as the "specialists" obviously can not be trusted :(
tzanis
Year and Model: 1997 850 GLT
Post by tzanis »
Hi. After replacing the the gear and putting back the cluster, I realized when driving in the dark, that the 3rd in a row from left to right light behind the cluster doesnt work (even though it worked before), and the speedo needle is way more faded (has minimum light) than the others. Also, the tracs light doesnt come on, although I swapped it with another one, it still doesnt go on. Any thoughts/help will be appreciated.
Post by Ozark Lee »
I replace all of the lamps, working or not, when I repair the gear anymore. The amount of jostling getting the cluster in and out will break the filament on used bulbs about half of the time. I had similar issues when I changed the gear on my first 850.
The main lamps are easy, any auto parts store will have them, but the smaller lamps are tougher to find. I think Robert (member name RSPI) sells the warning lights for considerably less than a dealership.
dosbricks
Post by dosbricks »
tzanis, I'm not sure if your '97 has an option to reset your service reminder light, but my '96 did not, so I pulled that bulb when I replaced my odo. gear. Just a thought.
