Need a rebuild TRW rack for 97-850
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
Previously mentioned "honey-like fluid". Aren't a couple of the motor mounts liquid filled? I've seen them on some cars, don't know about the Volvo though.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
The two front subframe bolts will come off when it is put back together with thread-locker. That would be a good time to look closely for the source.rmmagow wrote:Previously mentioned "honey-like fluid". Aren't a couple of the motor mounts liquid filled? I've seen them on some cars, don't know about the Volvo though.
The hydraulic function used fluid like oil. Is there some in the subframe bushing?
Ben850
- Been thanked: 7 times
"The hydraulic function used fluid like oil. Is there some in the subframe bushing?"
No fluid in the subframe bushings. They look much like the upper engine torque bushing by the cam sensor.
http://www.fcpeuro.com/products/volvo-s ... Mgod5lAAnQ
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
xHeart
Fluid of choice. From Lee to Justin, Erik, and y'all.
Valvoline Max Life, it has MVS preferred ingredients - a right blend, can't be wrong.
xHeart
Starting to put it back together.
Serviced the rubber boot, bearing, collar at steering column, and the u-joint, all move with little to no resistance.
The creak noise as you turn steering could also come from the collar/flange, a three piece plastic assembly, size as the boot. You would hear it when handled. It is placed between the boot and the floor. It comes out with a spray of soap water, and gentle counter-clockwise turn.*
These come apart, lubricate lightly, snap three pieces together. Careful pushing the clips on the flange.
Spray the rubber boot with soap water and slide the collar back into place while rotating clockwise.
After little sanding, WD40, and cleaning spline it look ready for work. * a credit to JRL for insight into this service
xHeart
The rack is now going in this afternoon. The tie-rod end is installed with correct measure.
There is a note from JAC, do I adjust the clip?
- Been thanked: 504 times
Yes,
Use white-out to mark the top position of the boot.
Then whatever you do, make sure the boot stays in the same position.
xHeart
As always, timely. Thank you!
It worked out effortlessly.
A Martini...
A Martini...
- 982 Views
Last post by Matty Moo
- 1899 Views
Last post by E Showell
- 319 Views
- 9 Replies
- 2663 Views
Last post by shiloh51933
- 732 Views
Last post by vtl
