Need a rebuild TRW rack for 97-850
rmmagow
Year and Model: V70 1998
Post by rmmagow »
Previously mentioned "honey-like fluid". Aren't a couple of the motor mounts liquid filled? I've seen them on some cars, don't know about the Volvo though.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
rmmagow wrote:Previously mentioned "honey-like fluid". Aren't a couple of the motor mounts liquid filled? I've seen them on some cars, don't know about the Volvo though.
The two front subframe bolts will come off when it is put back together with thread-locker. That would be a good time to look closely for the source.
The hydraulic function used fluid like oil. Is there some in the subframe bushing?
Ben850
Been thanked: 7 times
Post by Ben850 »
"The hydraulic function used fluid like oil. Is there some in the subframe bushing?"
No fluid in the subframe bushings. They look much like the upper engine torque bushing by the cam sensor.
http://www.fcpeuro.com/products/volvo-s ... Mgod5lAAnQ
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
xHeart
Post by xHeart »
Fluid of choice. From Lee to Justin, Erik, and y'all.
Valvoline Max Life, it has MVS preferred ingredients - a right blend, can't be wrong.
Recommended use – Volvo is clearly on back label...
xHeart
Post by xHeart »
Starting to put it back together.
Serviced the rubber boot, bearing, collar at steering column, and the u-joint, all move with little to no resistance.
The creak noise as you turn steering could also come from the collar/flange, a three piece plastic assembly, size as the boot. You would hear it when handled. It is placed between the boot and the floor. It comes out with a spray of soap water, and gentle counter-clockwise turn.*
These come apart, lubricate lightly, snap three pieces together. Careful pushing the clips on the flange.
Spray the rubber boot with soap water and slide the collar back into place while rotating clockwise.
After little sanding, WD40, and cleaning spline it look ready for work.
u-joint connects rack with steering column
* a credit to JRL for insight into this service
xHeart
Post by xHeart »
The rack is now going in this afternoon. The tie-rod end is installed with correct measure.
There is a note from JAC, do I adjust the clip?
Technician note...
Technician note...
Been thanked: 504 times
Post by cn90 »
Yes,
Use white-out to mark the top position of the boot.
Then whatever you do, make sure the boot stays in the same position.
xHeart
Post by xHeart »
As always, timely. Thank you!
It worked out effortlessly.
A Martini...
steering fluid releasing air bubbles.
Post by cn90 »
Good Job!
As they say: winners don't quit and quitters don't win.
Glad you are persistent.
