1999 V70-XC vibration in steering wheel at idle
Brick Head
Year and Model: 1999 V70XC
Post by Brick Head »
I have a "what's wrong?" type of vibration in steering wheel at idle and while driving at low speeds. Watching from above as wife shifts between Drive/Reverse repeatedly there is about 2 inches of forward and backward play at the top motor mount. Upon inspection the rubber insert appears in good condition. I've replaced the obviously broken passenger side engine mount and the transmission torque mount. Viewing from underneath all mounts show zero movement while wifey shifts.
She runs GREAT. Tranny shifts GREAT. PS pump is quiet and recently flushed with correct green Pentosin.
Could the top mount really cause this vibration through the steering wheel? Again I have not replaced since it appears in good shape.
Or have I just answered my own question? :?
Thanks in advance -
Curt
1983 240 Wagon 260k
1985 760 Turbo (dead and gone)
1991 740 Turbo wagon (gone)
1999 V70 XC
2004 S60 T5
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
Vibrations at low speeds usually mean bad mounts. Usually the front lower. What type of mounts did you install?
There is a chance that you have a blown sub-frame mount...
Brick Head
I've replaced the passenger side engine mount (behind the wheel)and the transmission torque mount link on the driver side. Can you tell much by a visual inspection or is dis-assembly required?
1983 240 Wagon 260k
1999 V70 XC
2004 S60 T5
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
He asked what brand mount did you use?
Brick Head
Volvo tranny torque mount and Chinese-crap-but-in-stock passenger side mount. I should have mentioned these were replaced 3k ago during routine maintenance.
This problem has surfaced in the past 1000 miles. FYI the cheapo Chinese mount does look rock solid while the upper mount exhibits it's 2 inches of play.
1983 240 Wagon 260k
1999 V70 XC
2004 S60 T5
rspi
Post by rspi »
The upper mount likely will not cause a lot of vibration at idle. However, if you see movement there, I'd change the mount.
There is a chance that you have a bad subframe mount. They go flat sometimes, especially under oil leaks and with the age, have someone check them out or get under there with the car on ramps or jack stands.
