S60 Drivers window has a mind of its own!
When I close my drivers window with the one touch closure option the window will get to about 3/4 closed then stop and go back down again. Sometimes it will close all the way and then go back down but if I don't use the one touch option and just use the up switch the window works fine. I just use the press and hold method but it is a pain in the ass!!
JRL
- Year and Model: Several
- Been thanked: 16 times
Put the window up but hold the switch, it should go all the way up and hold the switch for 5 seconds after the window is up.
Sometimes that resets it
If not you either have a small blockage which the sensor is picking up or it will need to be fixed at the dealer on VIDA
JRL
You don't do it when it happens, you do it the next time you're near the car
JRL
Remember,, when you get in, put the window down then put it up by holding the switch up and continue holding it up after the window is fully up for a long 5 second count.
One-one thousand, two one thousand,etc.
Nothing to lose and sometimes this rests the window.
If it makes you feel any better once in a while mine does this too, the nature of the system.
As long as it DOESN'T do it most of the time ... I would not worry about it
- 1624 Views
- 1787 Views
Last post by RigsPGT
- 19 Replies
- 6237 Views
Last post by as400jockey
- 1677 Views
Last post by 2001XC70
- 3543 Views
Last post by aaronlife
