s 40 engine light on
tiolou21
Year and Model: 2006 s40
Post by tiolou21 »
had tuneup light went out next day light came on 88 k ? what next change manfld senors
JDS60R
Been thanked: 3 times
Post by JDS60R »
Have the codes read at your local auto parts stores for free and report back with the codes.
Retired
tiolou21
Post by tiolou21 »
failed emissions test codes p0171 system too lean bank 1, koer result failed, mil command status failed, what step do u take for p0171
zulu-v40
Year and Model: 2003 V40
Post by zulu-v40 »
This site will help you trouble shoot. Looks like starting with the Mass Air Flow sensor is recommended. Research how to clean the MAF on this forum.
2003 V40 T4, silicone vacuum hoses, K&N air filter, iPd Boost Gauge, iPd HD TCV, PowerSlot Rotors
tiolou21
Post by tiolou21 »
thanks zulu-40 very helpful, i was told also sensor on manfld bad, searched with numbers on part no co has that part with those numbers what is it called? one sensor on manfld one on each side. thanks in advance
zulu-v40
Post by zulu-v40 »
If you could submit a picture for reference, that would help a lot. I'm not familiar with your model year. It could be one of many different sensors.
