So progress has been quite slow on getting Big Red back on the road (weather, business travel, laziness, etc.), but we’re quite close. Dr. Brutal is concerned about the subframe having gotten bent in the accident, causing alignment problems.
From the (poor cell phone) image, you can see the bottom of the frame and a slight ‘wave’ in the metal running across the hole in the bottom of the frame - it should be a perfect circle. When he was inside the wheel well, he pulled the control arm off. The rear bolt was actually curved because of the impact. It was slight but enough to cause a challenge in getting the bolt out. I’ve not spent a tremendous amount of time inspecting the subframe for more damage, but I’m hoping I can just replace the bolt that was bent and be on my way.
My concern is that it may be unnecessary to swap the subframe. I have one on the parts car so it’s not a problem getting one, but I’d like to avoid the time & effort involved with getting an engine lift – actually two lifts, right? – and swap the frame and all the little bits involved. So I guess the bottom-line question is this; if there’s any damage to the subframe, no matter how slight, should it be replaced?
Subframe is Bent - but just a little
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- Been thanked: 504 times
No worry from the picture.
Many years ago I hit a big flat rock (icy day), it created a 5-mm dent in the middle of the subframe (just inner of the oil filter area) and yet no alignment issues.
Just button the car together and align it and see what happens.
If necessary you can adjust the camber on the front a bit.
That kind of damage probably won't change the caster at all.
So don't worry!
So don't worry!
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
I had the hardest time putting the center bracket nut at the steering rack installation. There is a bent right at the center, see the photo.
I couldn't put a socket to the nut there, hence used 17mm open-end wrench to loosen using rubber mallet, and later tighten, then used angle to determine the torque, like cn90 often tells us.
Previously, I had shown it to a local maestro, who said, it wouldn't change a thing.
anmartin44
- Year and Model: 1994 850 n/a
- Has thanked: 2 times
- Been thanked: 2 times
if you do replace it, it's not super hard if you have a cherry picker. mainly just the four subframe bolts and then unbolt the steering rack, control arms, swaybar endlinks and mounts and drops right down with a couple jacks. i was able to take it off by myself but you'll need two people to remount.
1994 850 na green 187k on body, 275k on motor(backwards?), unrestricted airbox, 960 TB, persus wheels, Lowered, IPD poly upper and trans mounts.
1974 144 k-jet m40 satin black, 250k on body, 25k on rebuilt motor(running...usually)
vjaneczko
Without Googling this (yup; lazy), are the control bolts supposed to be one-time use? I may leave the subframe in place and just replace the bent bolt with an old one from the parts car.
Oh, and I got something else from IPD;
Anyone care to theorize if the impact may have bent the four bolts attaching the subframe to the frame? If they're bent, I should probably order new ones in order to get the Poly Subframe Bushing Inserts installed.
2006 S60R - For ME!
2006 S60R - For ME!
Ben850
I installed these and re-used the original bolts. I am not sure to what degree, if any, my subframe was tweaked by my accident. I believe my accident had greater impact force than yours as my airbags deployed. The bolts were not effected at all.
I actually had to straighten the unibody a bit. But after everything was bolted back together, I have not even taken it for an alignment and there are no steering issues at all.
I installed the poly shims a few months after it was back on the road and there was only one subframe bushing that was slightly compressed. I figured the shims would tighten things back up.
A side note: I used a tin snip to trim the top edges of the shims to more of a point. That and the grease helped the tighter ones into place.
1996 850 Turbo Wagon White.
1994 850 N/A Wagon Black.
1997 850 Sedan Black.
1996 850R Wagon White.
vjaneczko
Trimming the inserts - good idea. I've seen a few posts on SwedeSpeed indicating they're tough to install.
2006 S60R - For ME!
2006 S60R - For ME!
- 21 Replies
- 1782 Views
- 488 Views
Last post by Clemens
- 1143 Views
Last post by lummert
- 854 Views
Last post by Sufbug
- 1487 Views
Last post by motormikeyman
