checking crankcase pressure
volvomadness
Year and Model: v70 2003
Been thanked: 9 times
Post by volvomadness »
Heard you can check crankcase pressure using the T on a s70 GLT.
Does anyone have a writeup or experience using this method. If so how what are the connections for the pressure gauge on the T. And what should the readings be?
Thanks Madness
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
What pressure are you looking for? Oil pressure or crankcase vapor pressure?
The only way I know of to read the oil pressure is to install an adapter in the pressure sensor hole. Book spec on oil pressure is 43 PSI according to Haynes.
For Vapor pressure it should, in a prefect world, be zero. I use a balloon on the dipstick tube and see if it tries to inflate.
mrwillie
Year and Model: 1994 855 base
Post by mrwillie »
Is there a way to guess where the system is clogged based on whether the dipstick or oil fill has more back pressure?
JDS60R
Been thanked: 3 times
Post by JDS60R »
The lower port on the oil collection box is the most common blockage.
Retired
