Sorry no pics, but I had such a frustrating time doing this I felt I should spend a few minutes sharing:
The youtube video I found does not match the interior of the 2005-2007 cars.
The parts from crutchfield came with useless instructions, but the guys on the phone helped me through it.
1. Disconnect the battery
2. Put the shifter in the middle, then pry up the trim around the shifter and move it as far back as you can, but careful of the wires going to the W button
3. Put the shifter all the way back
4. remove the two T25 bolts at the bottom of the radio/climate console.
5. pull out at the bottom then down, the whole thing should come down.
6. disconnect all cables from the climate and radio.
6. remove 3 T25 along the top back, and 2 T25 bolts on the back sort of under the climate module.
7. remove the ring of fake wood plastic around the front. see which clips do this. this was what I did not do that made it take forever.
8. pop out the climate module. it goes out the front
9. now you can pop out the radio.
if this helps 1 person i am happy!
8. the climate module has 3 big clips you
How to remove stock HU-650 from 2006 V70
jh_on_the_cape
- Year and Model: 2006 V70 n/a FWD
Bright Red 1994 850 Wagon, nonturbo, FWD, stickshift 150k-ish miles SOLD
2006 v70 FWD nonturbo, boring silver A/T, 200k miles
