I dont need full exahust. my hangers broke on my 99 s70 t5 and when the exhaust dropped it pulled the pipe at the turbo outlet right out of the flange.
I took it all off the car and dropped it off at a welding shop. they said they could probably fix it but couldnt garantee it cause the flange is some kind of "cast iron" so I am just waiting to see.
if they cant then I need to find a replacement piece from the turbo outlet to the center where it all joins right after the cat.
I dont want it loud and I dont want lots of cels either
how much and where to get s70 t5 exhaust ?
oldschoolvolvo
- Year and Model: 1979 242DL
check out eurosporttuning.ca
http://www.eurosporttuning.ca/mm5/merch ... 70-exhaust
their cat-back exhaust is not very loud...if you upgrade the downpipe as well it will be slightly louder. if you have connections at a dealer they might be able to get you a discount on a new stock downpipe, or just go to the junkyard and get one yourself.
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
- 18 Replies
- 11013 Views
Last post by erikv11
- 11 Replies
- 3078 Views
Last post by winebanks
- 10 Replies
- 1274 Views
Last post by hausmeister
- 1221 Views
Last post by dlundblad
- 731 Views
