Replacing o2 sensors?
- pkc303
- Year and Model: 1995 T-5R Yellow
- Been thanked: 3 times
This forum has plenty of diagrams. Try following each hose, paying particular attention to the elbows. They tend to rot out more often. If the hose crumbles, or leaves a nasty deposit in you hand, replace it.
1995 Volvo 850 T-5R Yellow
1997 Volvo 850R (sold)
2003 Volvo V70 2.4T, K&N air filter, (sold)
1996 Volvo 940 (sold)
1992 Volvo 740 Turbo (sold)
1990 Volvo 240 Wagon (sold)
1987 Volvo 240 Wagon (sold)
1982 Volvo DL (sold)
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Here's your first suspect - this is on the left side of the intake manifold between the PS pump and alternator.
Aside from that, look at anything going to the turbo, vacuum tree or intake manifold by the throttle body. You will have to remove the triangle-shaped piece of black plastic.
There really aren't too many vacuum lines; just check them all over like pkc said. There should be a diagram on your hood.
'98 S70 T5
2016 Chevy Cruze Premier
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
For anyone interested, Stylin' Motors is back in business and selling silicone hose kits for the Volvos - mine shoulud be arriving on the 26th!
http://www.stylinmotors.com/volvo.html
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
MatDesign84
- Year and Model: 1997,855 T5
Has anyone tried the seafoam brand penetrate? It is non flammable and they claim it works even better after heating something up because it wont just burn off. I might get that instead of PB blaster when I get around to doing mine.
Currently: 1997, 855 T5 | 1998 Subaru Legacy GT 2.5
Previous: 1997, 850 GLT | 1993, 850 GLT | 1988, BMW 325i, 1990 Volvo 240 DL
"That's good to know though in case they let loose again, but I swear if they do, I'll punch something." -jblackburn
Chuck21387
- Year and Model: none yet
I swear by sea foam penetrating oil....it's amazing....MatDesign84 wrote:Has anyone tried the seafoam brand penetrate? It is non flammable and they claim it works even better after heating something up because it wont just burn off. I might get that instead of PB blaster when I get around to doing mine.
rmmagow
- Year and Model: V70 1998
- Been thanked: 2 times
I used the Seafoam to help get a balljoint part off my Subaru. It worked very well I guess but I might have gotten lucky. PB always worked for me too.
1998 S70 135K - FOR SALE
2003 GMC Sonoma - 114K - POS
MatDesign84
Thanks for the responses on this old thread, I dont have that car any more but im giong to get some of this stuff when I see it in the store. Auto Zone or Advanced auto parts do not seem to carry it.
OLd thread alert, but this seemed to be the best thread after Search for O2 sensor replacement...
I have 140k on my 1999 V70 T5 - I have seen advice to replace at 100k, and other advice that if you arent throwing codes then dont replace.
My mileage is down, so Im leaning towards replacement, in which case I will try jblackburns progression of methods above..
Keywords O2 sensor replacement oxygen O2 wrench crow foot
I realize this post is a little dated but, maybe my experience can help someone else... I make no promises but this is my story... My 99 v70 xc 's engine light came on the other day. I went straight to AutoZone to have the code read and they said either the front o2 sensor or the catalitic converter. I read on here that someone fixed theirs by creating a lean mix by removing a vaccuum hose for a few minutes. The lean mix burned hot and burned off the buildup on the o2; engine light went off. Rather then messing with hoses I decided I'd try running some high octane fuel. I filled my tank with premium feul and added an octain booster/cleaner. 40 miles later the engine light went off and no problems since. That $10 bottle of octane booster saved me (potentially) hundreds of dollars!
eulogiosifuen
- Year and Model: volvo s70 98
I have a 08 s40 and trying to replace o2 sensor. I bought the special socket 22 mm and it was too big I read after taking it back that that is the size to use could I have a smaller size or is the 22 mm socket the only one used for this model.
Please help
Please help
- 11729 Views
Last post by packetfire
- 1433 Views
Last post by JDS60R
- 1497 Views
Last post by Webpirate
- 569 Views
Last post by oragex
- 3157 Views
Last post by 2001downunderxc70
