Replaced Alternator, now serptine belt slips off?
arekaye
Year and Model: S90 98
Post by arekaye »
Just replaced my alternator and managed to do it with the power steering still intact. Pretty much took off the radiator hose above it and removed my air filter cabin so I could pull the old alternator out. I did have one problem with the bottom left alternator bolt mainly taking that out from more inside of the car(not sure why they put it in backwards =\) and putting the new one in the bottom left bolt got stripped on the frame. So now my alternator has only the two holding it onto the power steering. Does the third bolt really matter for much? Seems like it just hooks on the frame, but I managed to put everything back together and got the pulley back on, but when I started the car and drove it I heard something get torn up, it was the serp belt. Noticed with a new one it's slipping off the alternator pulley first. Could this be the bolt problem or alternator pulley problem, or the regular tension pulley? Any help appreciated!
JerryC
Year and Model: 93 940
Post by JerryC »
Year? model? Serp belt? none of these cars had one, only v-belts.
Bolts, well the designers probably had a good reason to include the one now missing...
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Year and model are listed on the right under user name - as is yours.
The 960 and S/V90 do, indeed, have a serpentine belt.
I agree that the missing bolt is important or Mr. Volvo would not have put it on the car.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
arekaye
Post by arekaye »
Well the frame that holds the alt/ps pump had one of the top shorter bolts fit in perfectly. Took the bosch one I got back and the parts store just put on the old pulley to the new alt pulley and it works great now! S90's apparently have an extra gap in there, kind of annoying
billofdurham
Annoying but it works. Good job.
Thank you for the update.
Bill.
Previously:
