6 pin connector. What wire is which?
So I have a 6 pin connector I want to add RCA cables to. I need to know what wire is which so I can solder it up. I know which pin is which in the pic below, but what color wires do they correspond to? Thanks.
- RCA-Diagram.jpg (20.4 KiB) Viewed 1897 times
- 005 (640x346).jpg (160.96 KiB) Viewed 1897 times
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
Use an ohmmeter, even better a meter that has audible beep for continuity test mode, and probe a pin and touch each wire till you have indication of continuity. Keep in mind the plug face is reverse the plug in location for all but the Rt rear and 12V. The shielding wire is connected to the ground and usually to the cuff around the DIN plug.
