2000 V70 loud snap at base of windshield
VolvoS70Driver
Year and Model: 1998 S70 GLT
Post by VolvoS70Driver »
My 98 S70 does this as well. Figured it was an expansion / contraction thing as temperature extremes are when it shows up.
Doug
Doug
1998 S70 GLT Blk/Blk
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Same thing here... when it's cold out.
Funny things, these cars of ours. :-)
Also -> Amazon link
895meztz94
Year and Model:
Post by 895meztz94 »
Mine does the same thing in the cold when the heat starts to warm up
1999 Volvo V70 2.4 Base 207k miles and counting
2003 Saab 9-5 Linear
beoutside
Year and Model: 1999 xc v70 awd
Post by beoutside »
I read somewhere to check the 4 bolts under the intake cowling, that attach the dash? Mine has the same noise........ 1999 X/C will post if mine are loose.
1999 V70 x/c AWD
Go Forth and Seek the depths
that create spark in your life......
Or something along those lines :)
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
Sounds like the dashboard cracking from being too loose. Mine did that and it's because the dash bolts between the windshield and firewall are loose and need to be tightened. it's a big job. I have yet to get to mine so I just used a rubber tie-down to keep it from squeeking and cracking until I fix it. Gluck with your issue and let us know the results of your findings.
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
those bolts are loose because the plastic on one side or the other (or both) of the plastic strap where the panel nut the bolts threads into.
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
A bitter cold morning, started the heater, turned the knob to direct air to the windshield. After few minutes the snap startled me.
The crack, see picture, became visible when it got warmer inside the cabin. It is a hairline when cold, you won't see it.
crack in the dash front and center at the windshield
oldschoolvolvo
Year and Model: 1979 242DL
Post by oldschoolvolvo »
Yup...I've got this issue too. First time I remember it happening, I noticed the plastic had split around the alarm sensor.
-Mike
Current:
1979 242 DL
1998 V70 T5
1992 240 GL
