Evaps are all the same throughout the years
Buy a Behr (OEM supplier) without the blue box, save $$$
Who has done the evaporator replacement or paid a shop
JRL
- Year and Model: Several
- Been thanked: 16 times
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
I have this oneabscate wrote:I've got all the parts but don't have the release tool for the couplers...can anyone source that for me?
https://www.amazon.com/Lisle-37000-Condi ... disconnect
"Quick connect and slow disconnect" heard someone refer to them as that, had to laugh (it's true!)
These would be a better quality though (probably stiffer)
https://www.amazon.com/Lisle-39400-Angle ... _pr_sims_t
1995 850 GLT Wagon w/ 200,000 miles
wheelsup
- Year and Model:
Good find thank you, I agreeburnout8488 wrote:http://www.fcpeuro.com/products/volvo-a ... s70-mt2672
I used that for the o-rings on my '99. It worked perfectly, and even included an o-ring for the orifice tube and junction. One year later, no leaks and works great. This is much easier and cheaper than having to hunt through the dealer catalogs to find each individual o-ring.
Although that says for S70/C70, wonder if they are the same
wheelsup
- Year and Model:
Thanks guys I'm also going to replace the fan as well, mine has issues when it is cold and makes funny noises. Found some on eBay for $45. Seems like a good time to do it...
I did see that writeup, it is excellent, I even printed it out some years ago.
WOW!...so....it looks as if when this job is being done, one can fix thier rattling dashboard screws too right? I can see the edge of the window in the pics after he yanked the dash out. is this true? if so, that's all the reason I need to go in there and replace the Evap. my rattling dash is nerve racking.
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
I did one in 100° heat in Albuquerque a couple of years ago and vowed that I would never do another unless the car is loosing more than a can of freon every 60 days.
It took me 11 hours and 30 minutes. Do be prepared to fix dash tabs. If I were going to fix dash tabs I would likely do the evaporator while at it.
Hoosier Shadetree
- Year and Model: '96 855 Turbo, 99XC,
I replaced the evap and heater core on my wife's '99 XC and am gearing up to do the same repair(s) on my newly acquired '96 855 Turbo. Not a job for the impatient or inexperienced technician.
From my experience, if you do tackle this job, bag-and-tag EVERY nut, bolt, screw, etc., from the first one you remove to the last one. Especially note if you are missing any fasteners from a group, e.g. glove box insert. This task is time consuming, BUT, it will save you time and lots of frustration when you go to re-assemble your brick. Not to mention that it keeps your workspace tidy. Hope this helps.
Hoosier Shadetree
Hoosier Shadetree
"Why guess when you can know?"- Carroll Smith
- 27 Replies
- 15065 Views
Last post by manovlov
- 2521 Views
Last post by packetfire
- 1652 Views
Last post by mayorpeoria
- 10 Replies
- 2407 Views
Last post by pkc303
- 12 Replies
- 4883 Views
Last post by Goupil
