1999 V70 T5 Ignition Switch replacement with Pictures 9447804
This topic is in the MVS Volvo Repair Database » Ignition Switch Repair: Electrical Fix - 1999 V70
Been thanked: 4069 times
Documenting replacement of the electrical part of the ignition switch on a 1999 V70
Typical symptoms - erratic ABS, CEL STS or other lights - often coming on after a bump in the road. May or may not be controlled by thumping steering column
Elapsed time from hood open to closed, 10 minutes.
Tools needed
Small Screwdriver, flat - easing open plastic case around steering wheel
11 mm wrench for negative battery terminal
Torx 20 bit
Torx 25 bit
4 inch extender
Replacement switch
Beer
Remove Negative Battery terminal, after finding radio code.
Drop steering wheel DOWN and OUT, if applicable
Remove three Torx 20 screws from bottom of steering wheel cover
Pop open two halves of cover and ease of bottom piece. Leave upper piece in place, per Alldata
Now remove electrical connector, just pull firmly to left. Remove two Torx 25 screws holding in switch (forget to photograph this, sorry. You can see screw holes in the picture.
New switch will go on only one way - note lugs on switch that pick up lugs in casing
Push new switch on firmly, there should be no gap between electrical switch and mount, as shown. Replace 2x Torx 25 screws before reinstalling electrical connector.
Reinstall electrical socket with pressure, replace steering wheel cover and 3 Torx 20 screws under cover.
Inspection of old switch - source of intermittent electrical problems pretty clear here..
Hopefully to last another 145,000 miles
reconnect battery, enter radio code, drink beer.
850 LPT
Has thanked: 335 times
Been thanked: 247 times
Post by 850 LPT »
Nice write up!
I had a little surprise when I removed the lower half of the steering wheel cover (step 2). When I took the three T20 screws out, the recessed holes literally fell apart. The plastic was all dry and brittle. I ended up glueing it all back together with a glue gun and laminated flatwashers into the holes to make them stronger. Volvo must have used cheap plastic for these parts :shock:
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
98T5
Year and Model: V70T5,98' / 940,93'
Post by 98T5 »
nice write up. very easy repair.
98’ S70 T5 Turbo Manual - Midnight
01' S60 T5 Turbo- Brandy
98' V70 T5 Turbo - Swifty
93’ 244 n/a - Mr.Chill
91' 940 SE Turbo - Mojo SOLD
83' 242 DL - Bluto SOLD
93' 940 Wagon - Django - SOLD
:mrgreen: 8) :mrgreen:
xHeart
Year and Model: 2.0/3.2
Has thanked: 116 times
Been thanked: 119 times
Post by xHeart »
Oktober Fest is coming early, I will start this replacement with St Pauli Girl.
Many thanks!
xHeart
Post by xHeart »
Replaced!
the ignition key feels firm at insert and turning at each position.
No more...
- light flicker,
- delay at headlights,
- delay clearing ABS and Tracs OFF at dash,
- scattered display of shift panel center console lights
- periodic loss pedal and shift
Bravo Zulu
Drink Swedish beer in celebration
Edited for beer referral
Steve-- Even the Swedes don't drink Swedish beer. It is that bad. Think Coors Lite, only worse. They resort to fine Danish alternatives, Carlsberg and Tuborg. Pripps Bla (missing diacritical mark) was awful when I was there, but that was four decades ago, so they've had time to improve.
xHeart
Post by xHeart »
would it help to go back in and apply a coat of di-electic grease to each pin?
Swedish beer would feel even better.
