850 T5 chip problem
Pedes
Year and Model: 850 T5 2.3 - 1994
Post by Pedes »
Hi,
I have a nice 850 T5 2.3 manual from 1994 with 340.000 km on the clock. It is in good stage 0 shape and has no oil or water consumption.
I bought 2 cheap tuningchips (50£) on ebay just for the fun of it, and have measured one of them on the dyno.
Result chip "1": 245 hp at 5400 rpm and 360 Nm at 4000 rpm.
Boost is approx. 0.8 bar.
I was promised 1 bar and 275 hp and 400 Nm on both chips.....................
However I am experiencing a studder/judder/cut-off feeling at full throttlle at approx. 4000 rpm, as if the ECU is cutting the power.
It comes with both original and tuned chips!
If I turn back the wastegate preset pressure I can make it go away, but then it feels sluggish building up pressure and power is down.
A vacuum hose to the WG fell of and it was able to make +++15 PSI at 2500 rpm, so the turbo is capable of spinning......... :mrgreen:
- Any ideas what is causing the 4000 rpm cut-off?
- Should I go through all the vacuum hoses again?
- How can I get a nice fat torque-burst at 3000 rpm?
Thanks for help - it is a fantastic website!!! :lol:
Volvo 850 T5 chip rullefelt.pdf
(112.6 KiB) Downloaded 257 times
burnout8488
Year and Model: 1999 S70 AWD
Post by burnout8488 »
Are these "chips" just little boxes that you splice into the MAF wiring? Or are they actually tuned ECUs that you installed?
Any "cheap" tuning chip for only 50£ I would worry that it is a scam.
'13 BMW X1 35i M-Sport
'99 S70 AWD/FWD - 198K - FOR SALE!
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
Sounds scummy..... Like that g-force trash you see advertised constantly.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
Buy a real tune please before you blow up your motor trying to build boost way too early. A boost spike at low RPM will create havoc in just a second.
That fuel cut above 4000 is the car trying to save you from destroying it without any real tuning whatsoever.
'98 S70 T5
2016 Chevy Cruze Premier
