I have a 2001 xc70 and I am also getting smoke from the oil sipstick at idle. no oil on the valve cover or anywhere else. Im wondering if its the small vacuume hose from the intake manifold to the catch box that might be plugged.
Has any one consired replacing the rubber hose / elbow with a pre 2000 elbow and adding a vacuum line directly off the catch box ?
Dip stick has smoke coming out still
mrjacobrussell
- Year and Model: 2006 s60R
- Has thanked: 2 times
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
2005 v50 t5 AWD for sale
I have a Chinese DICE, works well.
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
- Been thanked: 504 times
Since I put in the 5/8" hose, no more smoking dipstick.
See the DIY below.
https://www.matthewsvolvosite.com/forums ... hp?t=53448
See the DIY below.
mrjacobrussell
What about those of us with the special small vacuum hose on the elbow on the oil trap box that goes straight into the intake manifold ?
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
mrjacobrussell
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
mrjacobrussell
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
mikealder
- Year and Model: V70 2000
- Been thanked: 13 times
If you still have the PCV tank off the car attach a 5/8" I/D hose to the lower port in the engine block where the PCV tank connects, try to blow through this, if you can blow through it and hear bubbling the port is clear, if you can't then it is blocked.
You can see why it is difficult to clear the oil drain port in the bottom of the sump when you look at this picture, the red arrows show where the PCV oil drains back to the sump:
- Mike
- Mike
mrjacobrussell
Is this the drain or the pvc vacuum side.
Since i did the hose, smoke vapor from the dip stick is almost gone.
I'm thinking about adding a aftermarket catch can.
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
mikealder
The picture is the oil drain port from the PCV tank, it starts in the engine block then continues down to the base of the sump before turning upwards it is this upward portion that blocks and isn't possible to clean out working through the port on the front of the engine - Mike
mrjacobrussell
That might explain why i have oil in the intake.
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
In southern Oregon.
mikealder
As I said earlier connect a 5/8" diameter pipe to the lower port that the PCV connects to and blow through it as this is the easiest way to work out if the oil return is indeed blocked, if it there are a few things you can try to clear it out before resorting to dropping the sump.
I rodded the port out all the way to the base of the sump using some 1/4" clear plastic pipe, the carbon and sludge gets pushed in to the bore of the pipe as you feed it down in to the port, cut off sections of the clear pipe that are blocked and keep repeating until it comes out clean. At this point repeat the 5/8" hose and try to blow through it, if it is still blocked spray a load of carb cleaner down the oil drain port and leave it overnight, if this clears the port change the engine oil as the carb cleaner will be in the sump, well worth trying rather than taking the sump off - Mike
